When trying to install Niagara R2 version 2.301.330, the process halts and reports that Java Virtual Machine (JVM) is not installed. What version of JVM is required?
  • When trying to install Niagara R2 version 2.301.330, the process halts and reports that Java Virtual Machine (JVM) is not ins...
‎2018-09-07 03:16 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:27 AM
All Niagara R2 versions prior to 2.301.514 require Microsoft's Java Virtual Machine.
All revisions of Niagara R2 prior to 2.301.514 require Microsoft's JVM. To confirm if it is installed, open a Command Prompt window and type "jview" then press Enter. This command will display the current version of Microsoft's JVM (or that it is not installed).
Download and install Java_Virtual_Machine_for_WinXP.exe.
All revisions of Niagara R2 starting with 2.301.514 and beyond require Sun's JVM. To confirm if it is installed, open a Command Prompt window and type "java -version" then press Enter. Visit http://www.java.com regularly to keep the JVM updated. The Microsoft and Sun JVMs can co-exist on the same Niagara host computer.
  • TAC IA Series
  • 3543
