When starting SIGNAL, the following error message appears: User Build error, Btrieve # 910 INI path error
  • When starting SIGNAL, the following error message appears: User Build error, Btrieve # 910 INI path error
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 12:59 PM
New computer hardware was provided for SIGNAL.  The SIGNAL folder from the previous hard drive was copied and pasted to the new computer's hard drive.
When SIGNAL is started, a pop-up error message appears:
SIGNAL all versions
New computer hardware provided and the original floppy diskettes are not available.
The following two things cause this error:
  • Windows User Account must have administrative privileges
  • the \windows folder must have the bti.ini and signal.ini files
  • TAC IA Series
  • 6743
