When starting Niagara R2 Workplace Pro, a window appears stating: "Error occurred during initialization of VM. Could not reserve enough space for object heap"
  • When starting Niagara R2 Workplace Pro, a window appears stating: "Error occurred during initialization of VM. Could not rese...
‎2018-09-07 01:31 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:27 AM
The RAM spaces is not enough when it's trying to allocate to it.
If this error occurs on a Windows Server 2003 Service Pack 1 platform, read Technical Bulletin TB06-11.
If this error occurs on a Windows XP Professional service pack 2 (32-bit) platform, change the setting in /nre/lib/nre.properties to half of the maximum physical memory installed in the computer.  If the error continues to appear, an increase to 1 Gigabyte of RAM is recommended.
  • TAC IA Series
  • 2767
