When running Seven (Crystal) Reports on the same PC as ID Works
  • When running Seven (Crystal) Reports on the same PC as ID Works
  • sesa139513
    sesa139513
‎2018-09-06 03:04 PM
I/NET Site
Having issue when running Seven (Crystal) Reports on the same PC as ID Works
Using "Smart Printer Driver" set as the windows DEFAULT printer Seven Reports fails while attempting to display the query. You may first see a small window with '1/4o and a square". Before opening Seven Reports change your windows DEFAULT printer to another printer. Restart Seven Reports and run a query. The problem is due to the default paper size ID Works uses versus what windows uses.
  • TAC INET
Tags (4)
  • 2089
  • Datacard
  • ID Works
  • INet reports
