When running I/NET Seven rev. 2.15, in the I/O Server editor, the "CCTV" button is Grayed out
  • When running I/NET Seven rev. 2.15, in the I/O Server editor, the "CCTV" button is Grayed out
  • Tom_Poovey
    Tom_Poovey
‎2018-09-06 02:46 PM
  • I/NET
  • DVR
  • CCTV
Errors occurred during installation
CCTV new DLL file Install Process from I/NET Seven CD (Rev 2.14 and above)
  1. Load the I/NET Seven CD in the CD drive unit (D:\). The CD will try to auto-load, cancel that install. Then go to this location on the CD
    D:\Support\RVCTL_DLL\Rev 3.6.0.1
  2. Copy the three DLL files (ijl15.dll, rvctl.dll & rview.dll) from the CD. Then paste them into this location C:\Program Files\INET Seven
  3. You must register one of the copied DLL files into the Windows Registry. Please follow these steps:
    1. Open a “CMD” prompt. Use Start>Run, type cmd and select OK
    2. Type the following:
      Cd\
      Cd \Program Files\INET Seven
      Regsvr32 rvctl.dll
    3. You will see a message box with the message “DllRegisterServer in rvctl.dll succeeded”
    4. The CCTV Button in the I/O Server is now available to be used for integral DVR’s
  • TAC INET
  • 3095
