When performing an update MCI after adding a new ACS controller to an existing sublan, why is a Memory Failure error message generated?
  • When performing an update MCI after adding a new ACS controller to an existing sublan, why is a Memory Failure error message ...
  • sesa139513
    sesa139513
‎2018-09-06 03:13 PM
I/NET site
Since the existing sublan controllers are ASCs with each containing 20 points within the interface, memory limitation is likely exceeded. Clean-up the interface database by deleting the unused resident I/O points. Make sure ASC controllers are set to Internal before deleting points. Retry performing the MCI update for the newly added controllers.
  • TAC INET
  • 1665
