When installing UltiVist on a new OS/2 computer it fails to begin stating there's not enough space on c: drive.
  • When installing UltiVist on a new OS/2 computer it fails to begin stating there's not enough space on c: drive.
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 01:19 PM
When installing UltiVist on a new OS/2 computer, it fails to begin stating there's not enough space on c: drive.  However, c: drive has plenty of free space.
Pop-up error message reads as follows:
Setup is unable to copy the installation support file a:\~ins0762.lib to a temporary location.  Error 420
UltiVist
The primary partition size is an issue for UltiVist.
OS/2 can support partition sizes greater than 2 gigabytes if HPFS is selected over FAT.  UltiVist will NOT support a primary partition size of 2 gigabytes or greater and, as a result, it will think that there's insufficient capacity for writing data to the partition.
To confirm, open a Win-OS/2 window, go to file manager, and check the drive space.  If a partition of greater than 2 gigabytes has been created, the available drive space will display as zero.
Create a primary partition size of 1.99 gigabytes.  It can be HPFS or FAT.
Best practice:  Install only OS/2 on the primary partition.  Install UltiVist on an extended partition (typically d: drive).
  • TAC IA Series
  • 6117
