When entering a value of 1 into Code 08 on a 7780 HHC to enable all lights on, all the lights do not come on
  • When entering a value of 1 into Code 08 on a 7780 HHC to enable all lights on, all the lights do not come on
  • sesa139513
    sesa139513
‎2018-09-06 03:20 PM
When entering a value of 1 into Code 08 on a 7780 Hand Held Console to enable all lights on, all the lights do not come on.
I/NET Site using the Hand Held Console (HHC)
Code 08 on a 7780 enables the all lights on function. If you go to Edit/Controller/Configuration and select “all lights on”, this will accomplish the same thing. This setting enables 00DI to be used as a trigger to turn all lights on at once, regardless of time schedule, calculations or anything else. Like wise if you enter “Code” 09 in the HHC, all lights off will be enabled and 01DI can be used as the trigger. This can also be done in Edit/Controller/Configuration setting.
  • TAC INET
  • 1395
