When creating links between an Enterprise Server and a UNC, the process takes 2 to 3 minutes per link. Why?
  • When creating links between an Enterprise Server and a UNC, the process takes 2 to 3 minutes per link. Why?
  • sesa119747
    sesa119747
  • Kim_Baze
    Kim_Baze
‎2018-09-06 02:54 PM
  • Enterprise Server
  • UNC (Universal Network Controller)
The Enterprise Server station's address book may contain a UNC (or more than one) that does not exist or is offline.
If a UNC no longer exist or is offline, it will slows down the link creation process. Remove the entry from the address book and restart the station, or, enable the UNC so that it is online.
  • TAC IA Series
  • 2789
