When converting a card from the IMI system using the Flashpoint Video capture card, will the card work in the Datacard (ID Works)?
  • When converting a card from the IMI system using the Flashpoint Video capture card, will the card work in the Datacard (ID Wo...
  • Tom_Poovey
    Tom_Poovey
‎2018-09-06 03:30 PM
ID Works
I/NET
IMI
The Datacard system supports the TWAIN formats and the Flashpoints cards also use this format.
Yes, you can. The Datacard system supports the TWAIN formats and the Flashpoints cards also use this format.
  • TAC INET
Tags (3)
  • 897
  • Datacard
  • ID Works
