When converting a Niagara R2 server station from xml to db, the conversion fails with the following message: Could not create node "tridium.apps.ProgramNode".tridium.fo...
  • When converting a Niagara R2 server station from xml to db, the conversion fails with the following message: Could not create...
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 12:12 PM
ERROR: c:\niagara\r.301.529.v1\stations\PMHBASSERVER\config.xml(865566,98):
Could not create node "tridium.apps.ProgramNode".tridium.foundation.IllegalChildException E_ILLEGAL_CHILD_DUP_NAME {Command}
   at tridium.foundation.node.NodeLifeCycle.pasteErrorCheck(NodeLifeCycle.java:153)
   at tridium.foundation.node.NodeLifeCycle.paste(NodeLifeCycle.java:68)
   at tridium.foundation.prism.Prism.commitTransactionImpl(Prism.java:1484)
   at tridium.foundation.prism.Prism.commitTransaction(Prism.java:779)
   at tridium.foundation.prism.NodeTransaction.commit(NodeTransaction.java:76)
   at tridium.xml.node.NodeHandler.createNode(NodeHandler.java:105)
   at tridium.xml.node.NodeHandler.(NodeHandler.java:42)
   at tridium.xml.node.NodeHandler.startElement(NodeHandler.java:140)
   at tridium.xml.TParser.doSTag(TParser.java:225)
   at textuality.lark.Lark.reader(Lark.java)
   at textuality.lark.Lark.readXML(Lark.java)
   at tridium.xml.TParser.parse(TParser.java:121)
   at tridium.tools.DbAdmin.readXml(DbAdmin.java:472)
   at tridium.tools.DbAdmin.convert(DbAdmin.java:292)
   at tridium.tools.DbAdmin.main(DbAdmin.java:168)
   at tridium.tools.DbAdmin.main(DbAdmin.java:122)
   at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
   at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at tridium.nre.Nre.mainImpl(Nre.java:663)
   at tridium.nre.Nre.main(Nre.java:603)
Parse of XML failed.
----- End of input -----
Niagara R2
The conversion fails due to two program objects having duplicate names.
Open the xml file using a xml editor (like Notepad++).  Navigate to line # 865566, character # 98 and identify the program object's name.
Rename the program object by adding an additional character (like a number '1' or a letter 'a').  Save and close.
Run the conversion to db again.
  • TAC IA Series
  • 8218
