What's the best way to clear an existing database from a DMS3500 and DMS350A?
  • What's the best way to clear an existing database from a DMS3500 and DMS350A?
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 09:43 AM
DMS
DMS3500, DMS350A
Re-installing a database and want to ensure existing database is completely gone.
In the DMS3500, connect OPRIF and use Command Mode to type in the following command:  DBCLR.
Once complete, log back into the DMS3500 and begin a database installation.
In the DMS350A, sign-on the keypad and type the following command:  DBCLR.
Go to each connected DCM and set all 8 toggle switches to the ON position.  Cycle power to the DCM.  After 10 seconds, re-address the DCM and cycle power.
Once complete, use OPRIF to begin a database installation.
The DBCLR command and setting the toggle switches to ON are considered a 'hardware' clear of the database.
  • TAC IA Series
  • 15508
