What privileges are given to a Personnel object by setting its ExecutivePrivilege flag to true
  • What privileges are given to a Personnel object by setting its ExecutivePrivilege flag to true
  • AbeMeran
    AbeMeran
‎2018-09-06 02:10 PM
Can the executive privilege override features such as Door Forced Locked schedule and Threat Level
CyberStation
CX968x
ACX57xx
Need to override door force locked schedule for users with executive privilege.
The executive privilege attribute of a personnel object can only be used to override area/door locked down.
Note that the executive privilege attribute will be grayed out unless the Cyberstation key has the area lockdown option enabled.
  • 4527
