What may happen if the same IP address is used by more than one NPR?
  • What may happen if the same IP address is used by more than one NPR?
‎2018-09-06 11:55 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:26 AM
I/NET site
A duplicate IP address will cause a system error message in I/NET, and the NPR will not initiate the appropriate LED error code. (TCON 209, 2-27)
  • TAC INET
  • 1448
