What is throttling range?
  • What is throttling range?
  • Gary
    Gary
  • sesa116877
    sesa116877
‎2018-09-06 02:57 PM
Last Updated: Gary Schneider Alumni (Retired) ‎2022-08-22 02:22 AM
TAC I/A Series
I/A Series controllers
Setting a proper throttling range will allow for more accurate control of external actuators and devices.
Throttling range is the amount of change in the process variable that is necessary to cause the controller output to change from 0 to 100%. The controller output may be 4-20mA, a voltage range, or pressure range.
  • TAC IA Series
Tags (5)
  • 2644
  • band
  • gain
  • GaryMontague22
  • proportional
