What is the working range for a thermistor temperature sensor?
  • What is the working range for a thermistor temperature sensor?
  • sesa139513
    sesa139513
  • PaulFr
    PaulFr
‎2018-09-06 10:29 AM
What is the temperature reading range for the STP500?
All Continuum controllers
STP500 range
STX500 range
STD500 range
Clarification on read range required.
When connected to a Continuum controller the operating temperature range is: -30°F to +230°F, -34°C to +110°C
For readings outside this range, an active sensor with a 4-20mA or 0-10V output should be used.
Labels (2)
  • Field Devices
  • 12999
