What is the usual Controller LAN speed?
  • What is the usual Controller LAN speed?
‎2018-09-06 03:18 PM
I/NET Controller LAN
The baud rate for all controllers on the LAN must be set to the same. The default or typical LAN speed is usually sufficient for most installations.
The controller LAN speed is usually 19200 baud.
  • TAC INET
Tags (2)
  • 1479
  • kpbs
