What is the resolution of the default Continuum Menu pages?
  • What is the resolution of the default Continuum Menu pages?
  • sesa139513
    sesa139513
  • PaulFr
    PaulFr
‎2018-09-06 09:58 AM
Why do the default Continuum Menu pages not look "sharp" on very high resolution monitors?
Cyberstation V1.94
Only one set of default .bmp menu screens are provided with a Cyberstation install.
The default menu pages supplied in a Cyberstation V1.94 SP1 installation are bitmaps of 1020 x 662 resolution.
If you are using a very high resolution monitor with a much higher resolution you may want to re-draw these example menu pages to suit the sites requirements.
  • 14671
