What is the replacement for a Drayton CRL 240 Actuator / Valve assembly.
  • What is the replacement for a Drayton CRL 240 Actuator / Valve assembly.
  • Gary
    Gary
  • DavidChild
    DavidChild
‎2018-09-10 12:21 AM
Last Updated: Gary Schneider Alumni (Retired) ‎2022-08-19 05:52 AM
The Drayton CRL 240 Actuator / Valve assembly is to be replaced.
Field Devices
  • Replacement
  • Drayton
  • Actuator
  • Valve
  • CRL 240
The Drayton CRL 240 Actuator / Valve is obsolete
The Drayton CRL 240 Actuator / Valve assembly is obsolete and there is no purpose built replacement.
The associated Drayton Valve Body was available in numerous sizes.
These sizes are not available in current combined Actuator / Valve designs.
To replace one of the above Actuator / Valve Body combinations the following are required :-
  1. Valve sizes ½” – 2”
    1. Valve – MB(1/2" - 2")
    2. Actuator -  MD10B-230 (  MD20B-230 could  be used if MD10B-230 is not available)
    3. Auxiliary Switch - MD-S1 ( MD-S2 could be used if MD-S1 is not available)
    4. Linkage Kit - LMD/AR-MB
    5. or the RM3601 actuator without the need for a linkage kit
  • Linkage Kit
  • Select S-E LMD/AR-MB Linkage Kit. (914-1071-000)
  1. MBF Valve sizes 65mm – 100mm
  • Could be replaced by the VTRE range
To view the MB Valve Data Sheet, please click here.
To view the MD10B Actuator Data Sheet, please click here.
To view the MD-S1 Auxiliary Switch Data Sheet, please click here.
To view the LMD/AR-MB Linkage Kit Data Sheet, please click here.
To view the LMD/AR-MBF Linkage Kit Data Sheet, please click here.
To view the RM 360 data sheet please click here
  • Field Devices
Tags (3)
  • 5449
  • crl240
  • GaryMontague22
