What is the replacement for a DRT 3801, DRT3851 Sensors with fan switches.
  • What is the replacement for a DRT 3801, DRT3851 Sensors with fan switches.
  • sesa139513
    sesa139513
  • Gary
    Gary
‎2018-09-11 01:03 AM
Replacement
Current replacement.
Obsoletion of device
The is no direct replacement for the DRT 3801, DRT3851 Sensors with fan switches.
The sensor and setpoint can be replaced using a New Part No. STR612/004604700
The fan switches would need to be replaced using a four position switch.
Click here to view the DRT3801/DRT3851 data sheet.
  • Field Devices
  • 12643
