What is the order of operation for event sequence
  • What is the order of operation for event sequence
  • sesa139513
    sesa139513
‎2018-09-06 03:12 PM
What order of operation does the event sequence use?
I/NET site
The event sequence runs in a linear manner. They must run from the first item in the sequence through to the last item in the sequence. Once started, the sequence must finish before it may be called again.
  • TAC INET
  • 1690
