What is the operating environment of Continuum controllers
  • What is the operating environment of Continuum controllers
  • Chris_Asbury
    Chris_Asbury
  • sesa139513
    sesa139513
‎2018-09-06 10:11 AM
What is the operating temperature / humidity of Continuum controllers
Continuum
B3xxx
i2xxx
IO module
ACX52xx
ACX54xx
CX9xxx
The operating Environment for the Continuum controller range
The operating Environment for the Continuum controller range is as follows:
Temperature
32°-120°F (0-49°C)
Humidity
10-95% RH (non-condensing)
This is the maximum Temperature and Humidity within the controller(s) enclosure, if the room is at 49°C then the temperature within the enclosure may be much warmer.
  • 13932
