What is the minimum recommended requirements for a host workstation with I/Net 2000 on it?
  • What is the minimum recommended requirements for a host workstation with I/Net 2000 on it?
  • sesa139513
    sesa139513
‎2018-09-06 03:22 PM
I/NET 2000 Site
Pentium Class Processor 200 MHz or greater 32 MB of RAM 200 MB of Hard drive space CD-ROM drive Video Display of 800 x 600 Windows 95, 98 or NT. Windows 2000 or ME will not work with I/Net 2000 Mouse.
If you plan on using an Ethernet LAN, the following will be needed. TCP/IP capabilities Static IP Address IP Mask Gateway IP address
  • TAC INET
  • 1298
