What is the maximum string length for a Server name?
  • What is the maximum string length for a Server name?
  • sesa139513
    sesa139513
  • PaulFr
    PaulFr
‎2018-09-06 10:38 AM
What limitations are in there when entering the SQL Server name in database initialization?
Installing Continuum Cyberstation and Web Client
The number of characters is limited in the database initialization screens for Server, Workstation and Stand Alone installations.
When entering the SQL server name in Database Initialization this is limited to a maximum of 30 characters.
Should your server name exceed this you can use the servers IP address, or map a network drive.
  • 12612
