What is the easiest way to tell if a point is being exported due to alarm attachments or programs?
  • What is the easiest way to tell if a point is being exported due to alarm attachments or programs?
  • ScottLeedberg
    ScottLeedberg
‎2018-09-06 02:51 PM
Listview
Run a quick report on which points are exporting data outside of the system.
The easiest method to determine what points are exported is to run a listview of points and have the column "Export" in the listview. Every point that is being exported will have a "True" in the export column.
  • 2905
