What is the difference between the AV-607, AV-609 and AV-607-1, AV-609-1
  • What is the difference between the AV-607, AV-609 and AV-607-1, AV-609-1
  • sesa119747
    sesa119747
‎2018-09-06 02:30 PM
  • AV-607, AV-607-1
  • AV-609, AV-609-1
Product information of a part number.
These rack and pinion linkages have been modified in the -1 revision to allow dual actuator mounts. Refer to document F-26752-12 or later to determine the dual actuator close off forces and where dual actuators are allowed. Dual actuators can not be ordered factory assembled. Order single actuator assemblies and field mount second actuator.
  • Field Devices
  • 3818
