What is the default password for a MicroNet LCD?
  • What is the default password for a MicroNet LCD?
  • Gary
    Gary
‎2018-09-06 02:11 PM
MicroNet controllers
Access level
Default password: -                  1234
It is worth noting that this password can be changed when programming.
With the 100 series range of MicroNet controllers a backup of the controller configuration would be required to identify the password if it has been changed from the default.
With the 50 series range of MicroNet controllers when the controller configuration is uploaded the LCD configuration should also be uploaded, the passwords can be found under properties when you are in the configuration LCD area.
  • Satchwell MicroNet
  • 4519
This is a heading
