What is the default IP address configured with a new jace-nxt for Niagara G3?
  • What is the default IP address configured with a new jace-nxt for Niagara G3?
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 12:50 PM
Jace-nxt
Jace-nxs
Initial powerup connection with Workbench
A new JACE-NX controller with Niagara G3 has the following TCP/IP settings for its two Ethernet ports:
Primary (top) port: 192.168.1.19n (static IP) with subnet mask: 255.255.255.0
     where the last numeral (n) matches the last numeral in the JACE's serial number
Secondary (bottom) port: disabled in BIOS, no assigned address
Usage of secondary port requires attaching a local console (keyboard, mouse, monitor) to the JACE-NX, rebooting the unit, then entering BIOS setup at power-on self test (POST) to enable the port.
Intended usage of the secondary port is for isolating a "driver's" Ethernet traffic from the primary port. Enabling the secondary port is generally discouraged, unless deemed absolutely necessary.
The primary factory-assigned IP address should also be listed on the packing slip that accompanied the JACE. If needed, change these IP network settings during your startup commissioning of the JACE.
  • TAC IA Series
  • 7035
