What is the baud rate when you are direct connected to a NPR 2000
  • What is the baud rate when you are direct connected to a NPR 2000
‎2018-09-07 12:13 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:26 AM
I/NET site
What is the baud rate when you are direct connected to a NPR 2000?
It is fixed at 19,200. (TCON 209, Serial Port Configuration)
  • TAC INET
  • 1420
