What is the Date format that the ID Works supports?
  • What is the Date format that the ID Works supports?
‎2018-09-06 03:30 PM
Is there a difference in the way Datacard (ID Works) handles the date format?
I/NET Seven
DataCard ID Works
Date format needs to be entered correctly when integrating ID Works with I/NET Seven
Yes, the format is different. The only format that the Datacard ID Works system supports are YYYY/MM/DD.
  • TAC INET
Tags (3)
  • 899
  • Datacard
  • ID Works
