What is an easy way to check ground connections?
  • What is an easy way to check ground connections?
  • sesa139513
    sesa139513
‎2018-09-06 03:17 PM
I/NET site
Take a multi-meter in a voltage setting, either ac or dc. Meter from controller ground to lan shield. You should read no greater than 250 millivolts. If you do read higher, go over ground connections to ensure they are good, metal to metal connections
  • TAC INET
  • 1512
