What is a 7801R Relay Tap?
  • What is a 7801R Relay Tap?
‎2018-09-07 12:24 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:25 AM
I/NET site
This Tap functions identically to the 78010 Host Tap. It differs in that it has two Normally Open (N.O.) relay contact outputs for alarms. Therefore, set the Tap's address and baud rates as you would for the 78010. (TCON 101)
  • TAC INET
  • 1454
