What is a 78010 Tap?
  • What is a 78010 Tap?
‎2018-09-07 12:23 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:25 AM
I/NET site
The Model 78010 Tap directly connects a workstation to a host LAN. I can also connect a workstation to a controller LAN. This Tap can also be used in conjunction with an external modem for dial-in applications. (Refer to TCON 101).
  • TAC INET
  • 1453
