What is Meant by Semi Online System
  • What is Meant by Semi Online System
  • Katha
    Katha
Lt. Commander Katha Lt. Commander
‎2025-10-19 04:55 PM
on ‎2025-10-19 04:55 PM
Clarification on the term "Semi Online System" within EcoStruxure Building Operation environments.
    Device Administrator
The term refers to a specific system configuration used when full internet connectivity is not feasible for all components of the Building Management System (BMS).
A Semi Online System is designed for secure environments where internet access is restricted for core systems but still allows licensing and administrative operations. Here's how it works:
System Components
  1. EcoStruxure BMS Servers Network
    • These servers are not connected to the Internet.
    • They cannot access the License Activation Server.
  2. Device Administrator Computer
    • This computer is connected to the Internet.
    • It has access to the License Activation Server.
    • It can also connect to at least one field server within the BMS network.
Licensing Implications
  • The system is treated as online for licensing purposes.
  • Offline licensing workflows are not required.
  • Licensing and administrative tasks are performed via the Device Administrator, which bridges the gap between the internet and the isolated BMS servers.
Benefits of a Semi Online System
  • Security: Core systems remain isolated from the internet, reducing exposure to external threats.
  • Flexibility: Licensing operations can still be performed without requiring full internet access for all components.
  • Compliance: Suitable for environments with strict IT policies or regulatory constraint
  • KatharineVasquez25
