What happens if an I/STAT override is pressed twice?
  • What happens if an I/STAT override is pressed twice?
‎2018-09-06 03:25 PM
Using an I/STAT, what is expected to happen if:
  1. During an unoccupied time period the push button override button is pushed
  2. The override duration begins
  3. The same button is pressed before the timed duration is completed
I/STAT
Understanding the designed response will allow you to set customer expectations appropriately.
The point returns to its original state and the override is canceled. The override status light is off.
  • TAC INET
  • 1163
