What do the LEDs indicate on a MSC-NC or MSC-NCM?
  • What do the LEDs indicate on a MSC-NC or MSC-NCM?
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 12:20 PM
DMS
Communications is down on a jobsite.  Trying to troubleshoot the MSC-NCM.
Here is the function of each LED:
WDT:  indicates processor and MSC-NCM communication status.  One blink/second indicates that the MSC-NCM is communicating with at least one Microsmart controller.  Two blinks/second indicate that the MSC-NCM processor is functioning but the MSC-NCM is not communicating with any controllers.  If it is blinking very fast, the MSC-NCM processor is functioning but the MSC-NCM program has not been downloaded into the controller (hence, the system is down).
ALARM:  indicates a service or point alarm condition exists somewhere on the controller trunk
TxD:  indicates data transmitted
RxD:  indicates data received
DCD:  illuminates when the Data Carrier Detect signal is active (used with modems)
RING:  illuminates when the modem detects an incoming call
  • TAC IA Series
  • 7958
