What components make up the LON-TERM1 and LON-TERM2 terminators?
  • What components make up the LON-TERM1 and LON-TERM2 terminators?
  • sesa119747
    sesa119747
‎2018-09-06 02:56 PM
  • LON-TERM1 terminator
  • LON-TERM2 terminator
LON-TERM1 and LON-TERM2 terminators are required for MicroNet LonWorks network topologies.
The LON-TERM1 uses a capacitor in series with a resistor with each part having the following specs:
  • Resistor E19-607 52.3 ohms, +\- 1%, 1W, MF
  • Capacitor E13-468 47 uF, +\- 20%, 50WVDC, Elec
The LON-TERM2 uses a capacitor in series with a resistor with each part having the following specs:
  • Resistor E19-608 105 ohms, +\- 1%, 1W, MF
  • TAC IA Series
  • 2711
