What are the troubleshooting steps involved if EcoStruxure Building Activate Flex Server fails the required Wi-Fi Signal Strength test.
  • What are the troubleshooting steps involved if EcoStruxure Building Activate Flex Server fails the required Wi-Fi Signal Stre...
  • Mukesh_Sangwan
    Mukesh_Sangwan
Ensign Mukesh_Sangwan Ensign
‎2025-03-03 12:29 AM
on ‎2025-03-03 12:29 AM
EcoStruxure Building Activate Flex Server fails the Wi-Fi Signal Strength test.
  • EcoStruxure Building Activate Flex Server
  • EcoStruxure Building Activate Partner Portal
If the Flex Server Gateway is configured on Wi-Fi, it must achieve a RSSI value greater than -75 or value does not go below -80 more than 3 times. If these conditions are not met, Gateway will fail the test.
Below steps should be checked/followed to check the issue:
  1. Check Network Type: Ignore this issue if gateway is using a GSM network
  2. Verify Wi-Fi Receiver: Ensure the Wi-fi receiver is properly inserted into the USB port of the gateway
  3. Optimize Placement: Make sure the Gateway is near or in line of sight with the router to improve signal strength.
  4. Restart Router: Restart the router and check with your network provider for any issues.
  • MukeshSangwan25
