What are the return codes for the SendEmail function
  • What are the return codes for the SendEmail function
  • Carl_Slack
    Carl_Slack
‎2018-09-06 01:58 PM
How to troubleshoot email from controller
CX 9680
BCX 4040, 4000
BCX 9640
Troubleshooting SendEmail function.
Below are the error codes that can be returned when using the SendEmail function.
Sample code:
Example 1
Program File
'Fall-thru program that sends a simple email message to a recipient
Numeric EmailStatus
Sending:
EmailStatus = SendEmail ("addr1@abc.com", "Lights", "We need to
save energy")
Checking:
If EmailStatus is 0 then EmailErrorString = Success"
Error Code
Description
No error
1
Not called from a program
2
Illegal argument value
3
Illegal argument count
4
Not enough memory to complete the operation
11
Failed to create SMTP user session to the email server
13
Email queue is temporarily full. The user should retry later
14
Cannot connect to the email serve
15
Error in sending the sender information
16
Error in sending the TO recipient information
17
Error in sending the CC recipient information
18
Error in sending the BCC recipient information
19
Error in sending the subject
20
Error in sending the message
21
Error in sending the end-of-message
22
Error in disconnecting from the SMTP server
23
Failed to resolve SMTP server address
24
Invalid dialup settings
25
Failed to connect remote SMTP server
26
Modem port is in use
27
Email settings are not configured
  • 4907
