What are the point address to be used as lighting circuits?
  • What are the point address to be used as lighting circuits?
‎2018-09-06 03:29 PM
I/NET Lighting controller
Only certain points can be used to control lighting circuits. These are reserved.
Use points 0-7 with a bit offset of 0-7. You may also use 8-11 for indirect circuits.
  • TAC INET
  • 946
