Webstation shows 12 hour AM/PM time format even when the PC is setup to 24 hour format
  • Webstation shows 12 hour AM/PM time format even when the PC is setup to 24 hour format
  • Chris_Asbury
    Chris_Asbury
  • PaulFr
    PaulFr
  • Benji
    Benji
‎2018-09-11 07:55 AM
Webstation shows 12 hour AM/PM time and U.S date format even when the PC is setup to 24 hour and UK date formats
Webstation
Localization
Webstation does not get its time and date format from the Windows PC, but from the installed and selected language pack. To change the format, you need to install the language pack for your country or language.
There might not be language packs for all languages and countries, and unfortunately there is currently no option to UK/ European English in Webstation.
The workaround is to install a modified English language pack. Download and save and install one of the following two zip files, and install as described below.
DO NOT UNZIP THE FILE!
UK English 24 hours format with time zone indication
UK English 24 hours format without time zone indication
 While you are logged into Webstation, Select Settings, then Add or remove language
Select "Choose file" and browse to the location you downloaded the language pack .zip file to and select ok
Then under settings, select "Change regional settings"
You should now have the option to select "English (UK) (en-UK)"
you should now see that the date and time have now changed to UK format.
WebStation Language Pack UK English with tz - SmartStruxure Solution.zip
WebStation Language Pack UK English no tz - SmartStruxure Solution.zip
Tags (2)
  • 18074
  • datetime
100% helpful (3/3)
