Webstation - Need to log in twice when clicking on a TGML that leads to an object in a Xenta
  • Webstation - Need to log in twice when clicking on a TGML that leads to an object in a Xenta
  • sesa150561
    sesa150561
‎2018-09-06 01:38 PM
  • When logging in once the login screen appears again
  • Vista
  • Webstation
  • Windows 2003
  • Windows 2008
Windows 2003 server and 2008 server have different default security  settings for Internet Explorer and may deny cookies, this problem should not appear in Windows XP if default settings are used, you can also check if it works with Firefox, if it do so its ought to be the security settings in Internet Explorer.
When the problem occurs, there should be a notification after the address bar. Click on that and allow an exception for the IP address for the Xenta.
  • 5534
