Webreport - Reportserver does not delete the trend data when extended trendlog is deleted in StruxureWare Building Operation
  • Webreport - Reportserver does not delete the trend data when extended trendlog is deleted in StruxureWare Building Operation
  • sesa150561
    sesa150561
‎2018-09-06 09:31 AM
Reportserver does not delete the trend data when an extended trendlog is deleted in StruxureWare Building Operation.
  • StruxureWare Building Operation
  • Webreport
  • SQL
When an extended trendlog is deleted in StruxureWare Building Operation, its corresponding data in webreport server are not deleted. This means that when you want to look at a trend in the reportserver you will still see the deleted trendlog.
No new data are collected but the previously collected data will be there.
This is by design. The historical data are not deleted from SQL; however,  a side effect of this is that the webreport interface will still show the extended trendlog after it has been deleted in Workstation.
  • 16371
0% helpful (0/1)
