Warning when importing XIF file generated by XBuilder
  • Warning when importing XIF file generated by XBuilder
  • Benji
    Benji
‎2018-09-11 01:54 PM
When importing a XIF file generated by XBuilder a warning (that might look like it's an error) is shown regarding missing file name and generated date
SmartStruxure
Xenta Server
XBuilder
The XIF file generated by XBuilder doesn't completely follow the LONMARK Device Interface File Reference Guide
The warning can be disregarded, but the XIF file can easily be altered to avoid getting the warning if desired
Open the XIF in notepad or similar editor, and change the following. Note the colon before the filename.
Original XIF header
File generated by TAC XBuilder version 5.1.9, XIF Version 4
Copyright (c) 2000 by TAC AB
All Rights Reserved. Run on 0000-00-00 00:00
Changed XIF header
File: X913.xif generated by TAC XBuilder version 5.1.9, XIF Version 4
All Rights Reserved. Run on Mon Nov 03 08:00:00 2014
All Rights Reserved. Run on 0000-00-00 00:00File generated by TAC XBuilder version 5.1.9, XIF Version 4
Labels (2)
  • 17122
