Warm and cold starts of Automation Server
  • Warm and cold starts of Automation Server
  • Reza
    Reza
  • AbeMeran
    AbeMeran
Lt. Commander Reza Lt. Commander
‎2022-04-12 01:21 PM
on ‎2022-04-12 01:21 PM
Users asked if it is possible to do a warm and cold starts of the Automation Server using the reset button on the physical hardware
Users may need to do a Warm/Cold start of the Automation Server
From V1.5 and higher, the Warm start of the Automation Server can only be done through the command from the Workstation Software.
From V1.7 and higher, the Cold start of the Automation Server can only be done through the command from the Workstation Software.
Please refer to the following Webhelp for more information:
Reset functionalities of the Automation Server
  • RezaAmirzadeh22
