Vykon Alarm Service client version 2.4 query wizard will not allow dates past year 2010.
  • Vykon Alarm Service client version 2.4 query wizard will not allow dates past year 2010.
‎2018-09-10 12:25 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:23 AM
When we open query wizard for building up any query after the year 2010, the maximum end date can be selected up to 2010 only.
The Vykon Alarm Service client version 2.4 query range contains a maximum query year of 2010 within the software code.
New VAS Clients (2.50 and 3.92) along with associated release notes have been placed on The Exchange Extranet website.  Please note that you must be a licensed BMS Partner to download the assets. For non-partner, please contact your Schneider Electric local branch or Partner for access.
The VAS_2.50_Client.zip file contains the VAS 2.50 Client Installer and associated Enterprise Server vas service module (vas-2.301.532.v2.jar). VAS 2.50 is for use with Enterprise Servers that utilize database management systems including Cloudscape, MSDE, Microsoft SQL, or Oracle. If currently using VAS 2.4x, upgrade to vas-2.301.532.v2 jar and VAS 2.50 client. If currently using VAS 3.xx, do not install this version. Download and upgrade to vas-2.301.532.v3.jar and VAS 3.92 client.
The VAS_3.92_Client.zip file contains the VAS 3.92 Client Installer and associated Enterprise Server vas service module (vas-2.301.532.v3.jar). VAS 3.92 is for use with Enterprise Servers that utilize MSDE, Microsoft SQL, or Oracle database management systems only. VAS 3.92 Is not compatible with Cloudscape. If currently using VAS 3.xx, upgrade to vas-2.301.532.v3 jar and VAS 3.92 client. If currently using VAS 2.4x, do not install this version. Download and upgrade to vas-2.301.532.v2.jar and VAS 2.50 client.
  • TAC IA Series
  • 5450
