Vista webstation - HTTP GET method not implemented (SOAP-ENV:Client)
  • Vista webstation - HTTP GET method not implemented (SOAP-ENV:Client)
  • Benji
    Benji
  • sesa150561
    sesa150561
‎2018-09-11 08:27 AM
  • Cant login to webstation
  • Loginpage for webstation
  • Vista
  • webstation
Mostly  caused by that another process is using the same port as webstation do
Run the command netstat -aonb | find ":80" in the command prompt to see what process PID is taking the port 80, If Vista is using another port change 80 to what port you use.
A common scenario is that it is the TAC Vista SmartStruxure interface that is taking the port, and that after a reboot, the interface starts up before the IIS.
Change the port used in the interface to something else
Labels (2)
  • 17788
