Vista leaves a number of files in the root directory of the drive that Vista is installed on.
  • Vista leaves a number of files in the root directory of the drive that Vista is installed on.
  • sesa177673
    sesa177673
‎2018-09-06 01:53 PM
The following files are left in the root directory of the drive that Vista is installed on:
eula.1028.txt
eula.1031.txt
eula.1033.txt
eula.1036.txt
eula.1040.txt
eula.1041.txt
eula.1042.txt
eula.1049.txt
eula.2052.txt
eula.3082.txt
globdata.ini
install.exe
install.ini
install.res.1028.dll
install.res.1031.dll
install.res.1033.dll
install.res.1036.dll
install.res.1040.dll
install.res.1041.dll
install.res.1042.dll
install.res.1049.dll
install.res.2052.dll
install.res.3082.dll
VC_RED.cab
VC_RED.MSI
Vista 5.1.5
A bug in Microsoft's Install Shield which is a software tool for creating installers or software packages.
Delete the files shown under "Issue".
  • 5042
