Vista error "Can not connect to TAC Vista Server, No such interface supported"
  • Vista error "Can not connect to TAC Vista Server, No such interface supported"
‎2018-09-06 01:32 PM
Logging into Vista Workstation results in error:
Vista
Some connection between the Vista Server and the LNS Server has been broken. This is because of some change to the PC configuration: virus scan, Windows updates.
You have installed a component of a different version.
  1. Uninstall TAC Vista, system plug-in etc.
  2. Delete any TAC Shared folder in the \\Program Files\Common Files catalog
  3. Reinstall Vista
  • 5693
