Vista email - Error "Unable to relay"
  • Vista email - Error "Unable to relay"
‎2018-09-06 12:41 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:23 AM
  • Unable to relay
  • Email not working
TAC Vista
  • Vista
  • SMTP
If an error "Unable to relay" is returned, this is most likely because authentication is not sent to the SMTP server.
  1. Go to Vista Server settings
  2. At the email tab set proper authentication (TAC Vista Technical Manual Chapter 3.3 explain this more in detail)
  3. You may need to consult with the IT department on site
For more information on troubleshooting sending emails from a Vista server, see Troubleshooting Sending Emails from a Vista Server.
  • 7444
